I can't say I'm super-experienced with Inventory Usage, but I did make a Default Table Data section for the Issues & Transfers application, so it should be pretty similar. And we're on 7.6.0.8, so I can't speak for any changes (or bugs) that may exist in 7.6.0.9. That said:
--Have you tried using different From Storerooms? Does it behave the same way regardless of which Storeroom you use?
--Chart of Accounts is an Org-level object. Is the account code you're testing with valid (not expired) and part of the Org you're using to test?
--Any chance there's some other customization causing it to NULL the field? Assuming you're doing this in a development environment, can you turn off ALL Automation Scripts and see if it works?
--In Application Designer, for the Section you added to contain your Default Table Data controls, are you certain that the Data Source ID is set correctly? In a default configuration, the value should be main_invuselinetab_table
--When putting values in your Default Table Data section, are you using anything else alongside GL Account? For example, if you also put Location or Asset, those objects will try to pull in their own default GL Accounts, and it should override what you've put in your Default Table Data section. So maybe that's happening and the processing logic is a little out-of-order?
Sent: 02-23-2021 10:13
Subject: Inventory Usage App - Prevent removing default GL Debit Acct
Travis,
Thanks for your response.
We're on Maximo v7.6.0.9
1) Yes, when I first add the new row the GL Account gets copied from the default table data.
2) Yes, item # is the only information I add after hitting the new row button.
3) As soon as I add the item number, the GL Debit Account field gets null'ed, not overwritten with a new value.
I hope this helps.
Megha
Megha Tatiya
Sent: 02-23-2021 09:25
What version of Maximo are you using?
When you add the item in the new line, you said it is removing the GL account:
1) When you create the row, the GL account field is definitely populated with the value from your Default Table Data section?
2) Is the item number the only piece of information you added?
3) When you add the item number, the GL account field gets NULL'd, or is it overwritten with a different value?
Sent: 02-22-2021 06:18
Any ideas or thoughts, anyone?
Megha Tatiya
Sent: 02-18-2021 07:21
Hello MORE Maximo Community,
I have created a Default Table data in the Inventory Usage app to default the GL Debit Acct and Issue To in all the Usage Lines.
However, when adding an item in the new line, it removes the Gldebitacct previously defaulted by default app table data.
I tried writing an attribute launch point automation script on item number run action to set the gldebitacct readonly but that doesn't work.
Any ideas how I can accomplish this?
Megha
Megha Tatiya
MIL Corp
