If you're reading this then you've probably downloaded one or more of A3J's mobile apps to access your IBM Maximo environment, but you may need some additional guidance on how to log in. No problem, the information below should help resolve your login issues and get you closer to making your work easier, mobile, and timely.
So, there are a few requirements you will need to get started no matter which app you are trying to use. These items consist of your Maximo URL, User Name and Password. This is the same information you would use if you were to log into Maximo on your computer's browser. Once you have this information, enter them onto the login screen and try logging in. If your login fails, then you will receive one of the error messages below depending on what went wrong.
Kevin Patel
A3J Group, LLC
