Hi everyone,
Good day!
I am currently working on a project in Maximo 7.6.1 and would like to check if there is a recommended approach or standard method to bulk data load or migrate Inspection Forms into Maximo.
Specifically, we want to know if configuration objects (such as questions, responses, form structures, and revisions) can be imported via Integration Framework (MIF), MxLoader, or any other automated script/utility, rather than manually recreating them through the UI.
If anyone has successfully implemented an inspection form data load process or has a sample Object Structure setup they could share, guidance or advice would be greatly appreciated.
Thank you in advance for your time and help!
Best regards,
#EverythingMaximo#MaximoVisualInspection#Safety------------------------------
Gopireddy Jaswanth reddy
thiran tech
