  • 1.  Delete all Meter Readings in a DEV environment using MxLoader
    Posted 09-03-2026 11:48
    Hello all,
    MAS 9.0.174
    I would like to delete all Meter Readings (Asset Meter Readings) from a DEV environment using MxLoader so I can then import a file containing the latest feed of a total list of meter readings for all assets as an exercise in preparation of Go-Live where Maximo is replacing a legacy system.
    Right now when using an MxLoader template using
    Object Structure: User Defined (very basic using the METERREADING object as the Source and given full authorization to MaxAdmin Group)
    For Object METERREADING
    I am getting a BMX error:  "BMXAA2870E - A Reading can only be deleted through the DeployedMeter for which it was created providading for the DeployedMeter"
    Does anyone have a procedure whereby I can safely delete all the rows in METERREADING and maintain system integrity of the MBO's?
    Jim MacDonald
    JMi Facilities
  • 2.  RE: Delete all Meter Readings in a DEV environment using MxLoader
    Posted 09-04-2026 13:19
    There's a system property (mxe.int.deletereading) that if enabled, should let you delete from the MIF. I'm not a fan of doing something that Maximo won't normally let you do in the UI but for a non-production scenario, it's less concerning.
  • 3.  RE: Delete all Meter Readings in a DEV environment using MxLoader
    Posted 09-04-2026 13:37
    Thanks Steven,
    I agree that I don't like changing default settings for fear of corrupting the database.  I looked for that settings inside the GUI but did not see it.
    Regardless, I would prefer to follow a process using MxLoader to delete these Meter Readings so I can load a clean slate without creating weird records that look like rollovers or Initial readings when not the case.
    Jim
    Jim MacDonald
    JMi Facilities
  • 4.  RE: Delete all Meter Readings in a DEV environment using MxLoader
    Posted 09-04-2026 13:47
    If your system doesn't have it, you can create it in the system properties application.
    Description: Allow to delete meter readings
    Value: 1
    Data Type: YORN
    Save and live refresh. I confirmed it is checked in 7.6.1.3 and MAS. And should work with MXLoader
