  • 1.  Inventory items not yet ready
    Posted 25 days ago
    Edited by Jason Johnson 25 days ago
    We would like to differentiate our inventory record quantities between ready and not ready. Meaning when we purchase inventory items, they go into a hold for review when received. But we would like to track their quantities in Maximo. Our solution was to add a custom attribute to the Inventory Balances table so that different batches of purchases can have their own "status". However, some statuses are not available to be issued. The problem is that the record's overall current balance sums all the balances, but we want to reduce the current balance by the amount in the various hold statuses. Does anyone have a better solution for an issue like this? Note that we are not using the Purchasing module.
    In the example below, we would like the record's overall current balance to only tally the "Active" balances and ignore all the others.
    Jason Johnson
    RSI
  • 2.  RE: Inventory items not yet ready
    Posted 25 days ago
    Aviation has a quarantine feature that's sort of nice to indicate you technically have some items, but they haven't passed inspection (mimic your QC HOLD situation). You then can progress it to make it available for the storeroom, send back to vendor, etc. I know they're evaluating features that exist only in the industry solutions to look to bring into core in 9.3 and later releases and that might be a good example. It still requires some sort of record (a PO, shipment, etc.) to track the parts coming in though.
    My best recommendation for a core Maximo environment if you won't have PO data is to create these in a QC type storeroom that then gets transferred into the actual storeroom. You can configure security to hide the QC storeroom from most people if you don't want them to interact with it. This way you're tracking balances in a separate storeroom & can transfer out after your review. Since you aren't using inventory reorder (since that would ultimately generate a PO), I can't think of an immediate downside to that approach.
  • 3.  RE: Inventory items not yet ready
    Posted 18 days ago
    Just demo'ed this idea with the stakeholders and it's exactly what they were looking for. Thank you for the outside the box thinking :)
    Jason Johnson
    RSI
  • 4.  RE: Inventory items not yet ready
    Posted 15 days ago
    Hi Steven,
    I was thinking about the "Inspection Required" flag, as the items get placed into a HOLDING location, but the trick is that POs are not being created.  So, the use of a dedicated QC store makes sense.
    I would also use the bin system as the labels for the status.
    What we don't know is how the item is progressed through each status.  I'm going to assume that it is by transfer rather than count adjusting.  By using the bins, this makes it so much easier to ensure that it goes from QC HOLD to QC PENDING.  It also provides traceability.
    There needs to be a rule (read automation script) that enforces that only those items that have a status (bin) of ACTIVE (?) can be transferred from this store to a "normal" store.
    As Steven mentioned about security, only give access to the store for select security groups.
    A more complicated approach is that you create a store per QC status.  This way, you can use the real inventory status on top of what security has been mentioned.  The downfall is that this would result in many storerooms, more complicated security, and you have to look in multiple stores for the overall profile of the QC item.
    Principal Consultant
    COSOL
    #IBMChampion
