LOCANCESTOR not including all parent paths in a networked location system
  • 1.  LOCANCESTOR not including all parent paths in a networked location system
    Posted 5 days ago
    I'm seeing some unexpected behaviour with a networked Location System in Maximo.
    My hierarchy is effectively:
    Substation A     Substation B
                 Route
                  Span
    The Route has two parents in LOCHIERARCHY, which is valid because the system is networked. The Span then has the Route as its parent.
    However, when Maximo populates LOCANCESTOR for the Span, only one of the two Substations is added as an ancestor. I expected both parent paths to be represented.
    I removed and re-added the Span -> Route relationship to force Maximo to rebuild the ancestry, but the result was the same.
    Looking at psdi.app.location.LocHierarchy, createLocAncestorsForParents() appears to recursively process parent.getParents(), so I would expect both Route parents to be traversed.
    However, it appears that Maximo could stop processing the remaining records in the parent set when an already-processed relationship is encountered. I'm wondering whether this could explain why only one parent branch is ultimately propagated into LOCANCESTOR, although I haven't yet proven that this is what is occurring
    Has anyone encountered this behaviour with networked location systems? Is LOCANCESTOR expected to contain all possible ancestors through multiple parent paths, or is there a known limitation/behaviour in how Maximo builds the ancestor records?
    Dirkjan van Rooy
  • 2.  RE: LOCANCESTOR not including all parent paths in a networked location system
    Posted 5 days ago
    UPDATE:
    After some additional digging and testing, it looks like the logic pushing ancestors down works fine.
    When I removed and re-added a higher-level parent link, both ancestor branches were filled in correctly on the grandchild location.
    So the result depends on the order the hierarchy is built.
    Dirkjan van Rooy
