Hello all,
Although the object I am importing to is the WORKLOG object, it really doesn't matter because what I am in search of is a procedure whereby I can take text from some source data and convert it as needed to successfully then import it import as fields of data inside workorder WORKLOGS.
The text format it is currently in does not generate an error when importing into the WORKLOG.DESCRIPTION_LONGDESCRIPTION field
Any help would be greatly appreciated!
Jim
Jim MacDonald
JMi Facilities
