  • 1.  Need procedure to enable import of Long Description values using MxLoader
    Posted 10-08-2026 17:20
    Hello all,
    Although the object I am importing to is the WORKLOG object, it really doesn't matter because what I am in search of is a procedure whereby I can take text from some source data and convert it as needed to successfully then import it  import as fields of data inside workorder WORKLOGS.
    The text format it is currently in does not generate an error when importing into the WORKLOG.DESCRIPTION_LONGDESCRIPTION field
    Any help would be greatly appreciated!
    Jim
    Jim MacDonald
    JMi Facilities
  • 2.  RE: Need procedure to enable import of Long Description values using MxLoader
    Posted 10-09-2026 05:55
    Hi Jim,
    I just want to confirm is the DESCRIPTION_LONGDESCRIPTION field included in your object structure?
    If you go to your object structure within object structures application > More Actions: Exclude/Include Fields > click Worklog object > click Non-Persistent Fields tab > confirm DESCRIPTION_LONGDESCRIPTION is included, image below.
    Sometimes by default it is not included.
    I am also assuming worklog is a child object within your object structure
    Joey Baah
  • 3.  RE: Need procedure to enable import of Long Description values using MxLoader
    Posted 27 days ago
    Hi Joey,
    Yes to all - I have been able to update the object structure as well as format a MxLoader sheet that enables Long Description import now!  Thanks for everything!
    Jim
