PM TROUBLESHOOT OR WO NOT GETTING GENERATED
Step-by-Step PM Troubleshooting Guide
1.Verify PM and Asset Statuses:Prerequisites for Generation.
For a Preventive Maintenance (PM) record to generate Work Orders, both the PM and the associated Asset must be in an active state:
- PM Status: Ensure the PM status is set to ACTIVE (Draft or Inactive PMs will not trigger).
- Asset Status: Ensure the primary Asset linked to the PM is in OPERATING status (Not In Service, Decommissioned, or Broken status will block generation).
2.Check the PM Cron Task Configuration:Automated Generation Schedule.
If the statuses are correct, verify that the automated background process is running properly:
- Go to System Configuration \rightarrow Platform Configuration \rightarrow Cron Task Setup.
- Search for the
PMDATACTRL Cron Task (or your organization's designated PM generation Cron Task).
- Check the Active checkbox to confirm the instance is turned on.
- Review the Schedule field to check how frequently it runs (e.g., every 10 minutes, daily at midnight).
- Check the History tab to confirm the task is executing successfully without errors.
3.Enable Background PM Generation in Organization Settings:System-Level Master Switch.
If the Cron Task is running but PMs still fail to generate automatically, check the global Organization-level setting:
- Go to Administration \rightarrow Organizations.
- Select your target Organization.
- From the Select Action (More Actions) menu, select PM Options.
- Click Administer Background PM Generation.
- Ensure the setting is turned ON / Active, then click OK to save.
Summary Checklist
| Component |
Required Setting / Check |
| PM Status |
Must be ACTIVE |
| Asset Status |
Must be OPERATING |
Cron Task (PMDATACTRL) |
Instance must be Active with a valid schedule |
| Org Options |
Administer Background PM Generation must be turned ON |
#EverythingMaximo------------------------------
Gopireddy Jaswanth reddy
thiran tech
