We use rotable components (engines, transmissions, torque converters, tilt cylinders, rock drills etc) on a communal basis. This means that if an engine for example is removed from machine 'A' and is taken out for repairs, it comes back to be used on machine 'B'. So, our rotable engine can be fitted and used in turns on a number of machines, say, 'A', 'B', 'C','D' and 'E'. The engine will have worked delta hours on each of these machines. The total life of the engine would be the sum of all those delta hours done on the machines. Question: where/how in Maximo 7.6.1 can we access the window that tracks and trends the components life (total cumulative hours) so that they can be decommissioned and discarded from the system once the stipulated hours have been attained?
Francis Bheura
Sandvik
