Triggering Native Add Row on Child Tables in IBM Maximo
  • 1.  Triggering Native Add Row on Child Tables in IBM Maximo
    Posted 25 days ago
    Edited by Aurelio Moura 25 days ago
    In IBM Maximo, adding a new record to the application's main object is straightforward. For example, an application based on INVUSE can use:
    to create a new record.
    However, adding rows to a child table, such as INVUSELINE within INVUSE, is different. There is no direct Automation Script method to execute the table's native Add Row action.
    Scenario
    INVUSE
    └── INVUSELINE
    Requirement:
    • User selects a row in INVUSELINE
    • Clicks a custom button
    • Maximo executes the table's native Add Row
    • The new row is automatically populated with values from the selected row
    Solution
    Create a custom button and use a WebClientEvent to trigger the native Add Row action on the child table.
    if launchPoint == "N_ADDROW":
        # Current row
        sourceLine = mbo
        mboSet = sourceLine.getThisMboSet()
        # Data to copy
        itemnum = sourceLine.getString("ITEMNUM")
        # Execute native Add Row
        uictx = UIContext.getCurrentContext()
        wcs = uictx.getWebClientSession()
        event = WebClientEvent(
            "addrow",
            "main_invuselinetab_table",
            None,
            wcs
        Utility.sendEvent(event)
        # Retrieve new row
        newLine = mboSet.getMbo(mboSet.count() - 1)
        # Copy values
        newLine.setValue("ITEMNUM", itemnum)
    Why Not Use MboSet.add()?
    In some cases, that is sufficient. However, when the goal is to reproduce the exact behavior of the table's Add Row button, including UI framework handling, triggering the native event is a better option.
    Key Discovery
    After: Utility.sendEvent(event) the original MboSet is automatically updated.
    The newly created row can be accessed immediately: newLine = mboSet.getMbo(mboSet.count() - 1)
    This enables solutions such as:
    • Duplicate Row
    • Copy Selected Row
    • Line Templates
    • Custom Add Row Actions
    Notes
    • Replace main_invuselinetab_table with your table control ID.
    • Requires an active UI session.
    • Assumes the new row is added as the last record in the MboSet.
    Conclusion
    While event="addrow" is sufficient for parent objects, child tables require a different approach.
    By creating a WebClientEvent and executing it through Utility.sendEvent(), it is possible to trigger the native Add Row action of a child table and immediately access the new record for further processing.
    The most interesting part is that the framework updates the existing MboSet, allowing the script to work with the newly created row without requerying or refreshing the relationship.
    Aurelio Moura
