  • 1.  Unable to login via sso
    Posted 05-22-2023 09:41
    We have 3 environments in maximo. For 2 we login via sso but for the other it asks for password. I have to make the other environment also sso enabled. I checked the WEBSPHERE settings and compare but nothing seems different, all been configured same way.
    There have been no changes to the websphere or to the xml files. Can anyone suggest what other things should I check so that we can login via sso?
    #Analytics
    #Architecture
    #CivilInfrastructure
    #HSE/OilandGas
    #Infrastructure
    #IoT
    #LifeScience/Calibration
    #Linear
    #MaximoForAviation
    #Nuclear
    #Procurement
    #Scheduling
    #Security
    #ServiceProvider
    #Spatial
    #Transportation
    #Utilities
    #WorkCenters
    Deepa P
  • 2.  RE: Unable to login via sso
    Posted 05-23-2023 04:21
    Hi Deepa - If you are saying all 3 environments Websphere settings, Maximo XML and Property settings are exactly same then it is not possible that 3rd instance asks for Password while not on other 2 portal. Pls check for all settings ob Websphere, System Property and web xmls again and you will find difference causing this.
    Sedin Technologies
    #IBM Champion 2022
    #IBM Champion 2023
