  • 1.  Where to update license file in 9.2
    Posted 10-08-2026 09:30
    Looking to update the license.dat in 9.2 and the place to do that is gone now. IBM haven't updated their docs, or I just cant find it if they did. Can I just replace the secret that stores it?
    Andy
  • 2.  RE: Where to update license file in 9.2
    Best Answer
    Posted 10-08-2026 13:23
    In 9.2 you want to go to the new App Point Usage application. Then in the triple dot in the top right click "Configure license consumption"
    That will allow you to upload the license and configure other settings that you used to be able to configure. You can also manually navigate to that page directly like:
    https://admin.YOURURL.com/license
  • 3.  RE: Where to update license file in 9.2
    Posted 10-08-2026 14:00
    Thanks - I didnt see that.
    I got "AIUCO1999E: Internal Server Error: a bytes-like object is required, not 'FileStorage' " when trying to upload the file so I might still just be adding it in openshift.
    Andy
  • 4.  RE: Where to update license file in 9.2
    Posted 10-08-2026 14:25
    Yes, this looks to be a known defect in 9.2 Known Issue: DT497779
    Looks like it should be fixed in the October release (it's documented as fixed but don't see it in the release notes of earlier versions yet).
