I am currently converting data from our old CMMS to Maximo. To assist in the conversion I have created a number of macro enabled files the take the data from the old system and creates an MXLOADER sheet prior to executing the mxloader RUN commarnd. I have created the following lines to assit with the execution,
Application.Calculation = xlManual
Application.Run "'MxLoader - Prod.xlsm'!MxRunAction"
Application.Calculation = xlAutomatic
The mxloader file is autoloaded as a hidden file when I start excel so that the "MxRunAction" is always available.
The problem I am having occurs when I try to use the current mxloader file 8.5.2.
- Can I execute the mxloader 8.5.2 run command from another file
- What does the code look like
AI gave me a non solution so I am turning to CI (collective intellegence) for help.
