There wouldn't be a supported work around. There are a lot of rules around cancelling like not having actual labor that you'd be able to do in edit history normally, so I think IBM opted for the easiest approach of not allowing edit history for CAN work orders.
You'd basically need to develop a hack around it where you have some custom object that you let be the owner of WORKLOG and have an app that lets you manage the custom object without worrying about the edit rules of the workorder. For example, you could have a non-persistent object called CUSTWORKLOG that you display in a dialog that stores information about the relevant workorder and then have WORKLOG as a child of it. On creation of the WORKLOG you can override the recordkey, siteid, etc. with the value of the wonum & siteid. It'd be a hack and definitely not supported by IBM but something like that should be technically possible.
