 Regarding restricting users from accessin Maximo upgrade from MAS 8 to MAS 9.1
Sandy S's profile image
Sandy S posted 10-08-2026 13:07
We are planning for prod cutover to upgrade MAS and Manage 8 > 9.0 to V9.1 and want to restrict the users from accessing the Maximo while upgrade activities are in progress.
What is the best approach
1) Enabling admin mode - will this interfere the upgrade process and cause issues? As per inputs received it may impact the overall upgrade process.
2) If not admin mode, can we update the user statuses to BLOCKED from backend till upgrade activity completes.
In test we had kept manage running for graceful upgrade and no admin mode was enabled.
Please suggest what practice is generally followed.
I don't recommend admin mode as the solution. During the upgrade there are cron tasks that need to run to synchronize the user data to Mongo. Admin mode prevents all cron tasks from running so your upgrade can't complete until you take it out of admin mode.
If you have SAML authentication, you can work to remove app access for those users until after the upgrade is complete. This will prevent them from being able to sign in without impacting any processes.
If you are using local auth (where the password is contained in Maximo), I would consider marking the users as INACTIVE/BLOCKED as you mention.
Wasn't part of the question but wanted to confirm that you're currently on MAS 8.X like 8.11 and not 7.6. If you're on 7.6, you can go straight to 9.1. But yes, if you're on 8.11 you would need to hit 9.0 and then 9.1. Like the 7.6 upgrade that still has cron tasks to work with the user data.
