We have Maximo integration with OSISoft Asset Framework using SOAP webservice. Using which we get PI-tag reading from PI to Maximo Asset meter.
From last couple weeks, integration is failing and we seeing below error in Maximo log files. We have not changed anything on Maximo and asset framework server but not sure why we getting this error. I enabled logging on Maximo site and confirmed that reading date that we get from asset framework is not future date. I worked with my server team and they confirmed that all servers have same time and they synced correctly.
Does anyone know what could be the problem and how to troubleshoot this issue?
[ERROR] [MXServerUI01] [] Processing failed for XXX_XX_METERDATA. The object structure is 1. The primary object is METERDATA. The key is null.BMXAA2895E - Future meter readings cannot be reported. Please enter the current date or a date in the past.
[7/15/21 19:28:39:572 UTC] 00000114 LocalExceptio E CNTR0020E: EJB threw an unexpected (non-declared) exception during invocation of method "wsSecureProcessExternalData" on bean "BeanId(MAXIMOUI#mboejb.jar#enterpriseservice, null)". Exception data: javax.ejb.EJBException: nested exception is: psdi.util.MXApplicationException: BMXAA2895E - Future meter readings cannot be reported. Please enter the current date or a date in the past.
#Assets#MaximoForAviation#WorkManagement------------------------------
Hardik PAtel
Corning Inc
