Dear Team,
We are unable to login to Maximo Anywhere as the login screen keeps rounding.Having set the device to USB debug mode,below are the messages observed from logs,Can someone please suggest what is the step we could do to resolve the issue
name: "storeNotFound", messageKey: "storeNotFound", params: Array(1), stack: "Cannot find the store called stagingTransactionQue…tion/no_backup/www/default/dojo/dojo.js:2:280291)"}messageKey: "storeNotFound"name: "storeNotFound"params: ["stagingTransactionQueue"]stack: "Cannot find the store called stagingTransactionQueue↵ at Object._getStore (file:///data/user/0/com.ibm.iot.maximoanywhere.workexecution/no_backup/www/default/js/platform/store/PersistenceManager.js:193:11)↵ at Object.getStageTransactionRecords (file:///data/user/0/com.ibm.iot.maximoanywhere.workexecution/no_backup/www/default/js/platform/store/PersistenceManager.js:1003:21)↵ at Object._flushStageTransactions (file:///data/user/0/com.ibm.iot.maximoanywhere.workexecution/no_backup/www/default/js/platform/model/PushingCoordinatorService.js:373:23)↵ at Object.flush (file:///data/user/0/com.ibm.iot.maximoanywhere.workexecution/no_backup/www/default/js/platform/model/PushingCoordinatorService.js:60:9)↵ at Object._synchronizeToTheServer (file:///data/user/0/com.ibm.iot.maximoanywhere.workexecution/no_backup/www/default/js/platform/comm/ConnectionHeartBeat.js:94:37)↵ at Object.connectDetected (file:///data/user/0/com.ibm.iot.maximoanywhere.workexecution/no_backup/www/default/js/platform/comm/ConnectionHeartBeat.js:58:9)↵ at file:///data/user/0/com.ibm.iot.maximoanywhere.workexecution/no_backup/www/default/js/platform/comm/ConnectionHeartBeat.js:47:12↵ at _7da (file:///data/user/0/com.ibm.iot.maximoanywhere.workexecution/no_backup/www/default/dojo/dojo.js:2:280291)"__proto__: Object "Cannot find the store called stagingTransactionQueue
rejected at _7e0 (file:///data/user/0/com.ibm.iot.maximoanywhere.workexecution/no_backup/www/default/dojo/dojo.js:2:280932)
at _7da (file:///data/user/0/com.ibm.iot.maximoanywhere.workexecution/no_backup/www/default/dojo/dojo.js:2:280543)
at _7d4 (file:///data/user/0/com.ibm.iot.maximoanywhere.workexecution/no_backup/www/default/dojo/dojo.js:2:280155)
at _7d9.resolve (file:///data/user/0/com.ibm.iot.maximoanywhere.workexecution/no_backup/www/default/dojo/dojo.js:2:281616)
at Object._reportConnectionStatus (file:///data/user/0/com.ibm.iot.maximoanywhere.workexecution/no_backup/www/default/js/platform/comm/_DeviceConnectivityChecker.js:201:28)
at Object.onSuccess (file:///data/user/0/com.ibm.iot.maximoanywhere.workexecution/no_backup/www/default/js/platform/comm/_DeviceConnectivityChecker.js:65:31)
at onConnectSuccess (file:///data/user/0/com.ibm.iot.maximoanywhere.workexecution/no_backup/www/default/worklight/worklight.js:8565:12)
at Object.bound [as onSuccess] (file:///data/user/0/com.ibm.iot.maximoanywhere.workexecution/no_backup/www/default/worklight/worklight.js:1023:27)
at klass.onSuccess (file:///data/user/0/com.ibm.iot.maximoanywhere.workexecution/no_backup/www/default/worklight/worklight.js:3800:26)
at klass.onWlSuccess (file:///data/user/0/com.ibm.iot.maximoanywhere.workexecution/no_backup/www/default/worklight/worklight.js:3773:12)
Error
at Promise.then._7e7.then (file:///data/user/0/com.ibm.iot.maximoanywhere.workexecution/no_backup/www/default/dojo/dojo.js:2:282104)
at Object.<anonymous> (file:///data/user/0/com.ibm.iot.maximoanywhere.workexecution/no_backup/www/default/js/platform/comm/ConnectionHeartBeat.js:45:28)
at HTMLDocument.<anonymous> (file:///data/user/0/com.ibm.iot.maximoanywhere.workexecution/no_backup/www/default/dojo/dojo.js:2:292076)
at dispatchForgroundEvent (file:///data/user/0/com.ibm.iot.maximoanywhere.workexecution/no_backup/www/default/worklight/worklight.js:16658:18)
at Channel.<anonymous> (file:///data/user/0/com.ibm.iot.maximoanywhere.workexecution/no_backup/www/default/worklight/worklight.js:16651:5)
at Channel.fire (file:///data/user/0/com.ibm.iot.maximoanywhere.workexecution/no_backup/www/default/worklight/cordova.js:813:23)
at file:///data/user/0/com.ibm.iot.maximoanywhere.workexecution/no_backup/www/default/worklight/cordova.js:226:49"
#Mobility------------------------------
Mahadevan Ramakrishnan
Tata Consultancy Services
