I've created a dashboard with some KPI's and a result set.
The KPI's are working correct.
I have an issue with the result set.
With the result set I want to show how many App points are used per day.
The list is working correct.
There are only 4 colomns in the table and using 2 in the result set.
When I click on chart view based on the date I only see the value 1 multiple times.
When I select the other colomn I see a count based on the value of that colomn but I don't want that.
How can I change this (without affecting other result sets) so that I can see the date with the correct value in the chart?
#Administration#Reporting------------------------------
Jim Scholten
Gemba
