Look at utilizing the overrideValues on the object structure (https://www.ibm.com/docs/en/mam/7.6.1.2?topic=structures-set-values-in-fields ). In the automation script application you create a launch point for integration, pick the object structure, and then say it's for outbound definition. Let me know if you have issues but especially for a simple transformation like this it should just work.
Sent: 12-06-2021 10:31
Subject: Automation Script transform outbound data
Is there a way to leverage the automation script to transform outbound data. API is setup with a request directly to an Object structure and one of the columns is in all caps that need to be all lower case.
Thanks.
Kirk Youngbauer
Great River Energy
