As we are in the process of implementing Maximo anywhere 7.6.4.we would like to understand what is the best way to redesign all the workflow validations in Maximo so as to support the mobility process.Do we need to remove all the workflow validations and implement it via the automation scripts for the same to fire when the status is being changed from the mobile application.What else are the possible solutions to redesign.
Mahadevan
#Customizations#EverythingMaximo#Integrations#Mobility------------------------------
Mahadevan Ramakrishnan
