In Work Order Tracking, the Inspection Form field becomes read-only once an inspection form is added and there is no way to modify or remove it. Job Plans and Safety Plans work this way as well, but there are options in the Select Action menu to remove them whereas there is no such option for Inspection Forms.
This ability is needed for Inspection Forms in case the incorrect form was selected by the user or if an inspection form was added inadvertently.
Projetech has opened an IBM RFE to add an action to remove Inspection Forms.
http://www.ibm.com/developerworks/rfe/execute?use_case=viewRfe&CR_ID=146612
Last week the RFE status was set to Planned for Future Release. If you are using Inspection Forms on work orders, please cast your vote for this RFE to get as much focus on this request as possible.
#WorkManagement------------------------------
Julie Shaw
