Hi Venkatrao,
Its not clear when you want to halt the work flow as you have put the status change logic to resolved post which the workflow will go to the next node which is the stop node as expected.If you would like to put a halt after the resolved status,you can configure to add another wait node and put the relevant condition when it should come out of that wait node.
If I didnt understand the scenario well,you can let me know what is the business scenario and I can let you know my thoughts.
Regards
Mahadevan Ramakrishnan
Sent: 02-06-2022 05:56
Subject: Wait node in Maximo workflows
Dear Everyone,
I am working on Maximo 7.6.1.
We have a requirement to send a notification to the maxadmin group when a user changes the status of an SR application to resolved.
Build: we have created a workflow with three nodes.
1.start, 2.wait, 3.stop
We have given the wait node event as maximo.sr.statuschange.resolved and the attached communication template has the maxadmin group.
Issue: The workflow is routing correctly, but when the user changes the SR status to resolved, the workflow does not stop and notification is not sent to Maxadmin at the start center.
Please kindly help if you come across the same issues and let me know if you need further information.
Venkatrao Y
