Agreed with the above, the field is actually persistent even though the description says otherwise. So you might start there.
The problem is that users can select values from the lookup to change the field even though the field
looks read-only, correct? I am wondering if you could place a restriction on JPTASKRELATION. That table is where the predecessor data is stored. You could try a global data restriction on the object perhaps, or an automation script that throws an error if the job plan is in active status.
Danielle Newhouse
Sent: 08-06-2021 10:09
Subject: Can we make the Jobplan task predecessor readonly ?
Dear Team,
Currently as per maximo desgin the Jobplan Task predecessor field is editable and allows to modify the data in ACTIVE status.
I want to restrict this field so that no one can edit or change the value once predecessor data filled.
The attribute predecessor is a non persistent and i am unable to restrict this from global data restriction.
Any help on this is highly appreciable.
Pradeep Rout
TCSL
