I asked a
question with the same subject, minus "discussion". Unfortunately, there's no way to comment or reply to questions raised in proposed answers. So, this thread is intended to fill that gap.
@Steven Shull: The way I get the value seems irrelevant. I have tried the way you suggested as well as the two I posted in my question, among others. The problem seems to be that the component never gets re-rendered. Instead, it seems like the generated HTML gets cached and reused.
@Jade Warren: The label presented in my question is a simplified test case. As in my comment above, I feel like I need to trigger a re-render, or to set a flag that says to re-render. I'll see if setting a property, as you do in the code sample you provided, causes a re-render.
#Customizations------------------------------
Jason Uppenborn
Ontracks Cohesive
