Hello community,
I have a strange problem with attachments in Anywhere 764. Work Execution.
Some information
1. Maximo EAM - 7608 (we are upgrading to 7612)
2. Anywhere 764
3. All server are Windows based + DB is MS SQL
4. LDAP authentication
When I try to download attachment to mobile device (iPad), the process in started, but the file that is download is logon form with extension of .pdf (the one that I try to download). After some log analysis I fount that the mobile app is tying authenticate again using maxauth (user:pass in base64) instead using already authenticated session and LtpaToken2, as result login form is downloaded as requested file with the extension of file requested (in my case test.jpg).
After I rename test.jpg to test.html and open with browser I see maximo login form.
Thank you in advance
Chavdar
#EverythingMaximo------------------------------
Chavdar Cholev
Home
