Hey Maximo Open Forum,
Did you know that you could tag threads and other MORE Community content? Tagging is a fantastic way to help sort and categorize the information you're already posting and sharing! Just use the '#' and the word(s) that follows (or phrase-remember, no spaces are allowed in hashtags!). When posting in the Maximo Open Forum, you'll also be prompted to select 1 or more Topics (tags).
You can see the tags in the body of the post or library resource (they appear as blue links). If you click on one, you will be taken to a search of all content using the same tag.
You can also see all the tags used in a post underneath it in the thread list. As seen in the picture above, this post had two tags associated with it. Just like in the post, if you click one of these tags, it will take you to a search of all content using that tag.
For any questions, do not hesitate to reach out!
-Mackenzie
#MOREOfficial#TipTuesday------------------------------
Mackenzie Sangster
Community Manager
MORE Maximo Community
