Maximo comes with the supervisor displaying the name, out of the box. The relationship looks correct, so you should only need to load the supervisor field on the person record, and when you display it in the people application, the corresponding name for that person should display.
Check the data you loaded and ensure it matches the present person data. You can always find a record that appears to have an error, select that person from the select value, and then save. If it works, you had a data error on the load, which I am guessing is the issue.
IBM Champion 2024
Sent: 04-19-2024 17:15
Subject: Updating Person Record
Good afternoon all,
I am wanting to update the person records in Maximo using MxLoader which has been such a great tool for which I am very grateful.
I added the Supervisor name in App designer.
The Supervisor ID pulls successfully, but I have not been successful in pulling the Supervisor name.
Does anyone have any suggestions on if this would be possible?
The setting for this attribute is: SUPERVISOR.DISPLAYNAME
Thank you in advance,
