I create object structure with FAILURELIST as the only object, no additional settings. When I run MxLoader query action, only get 2 rows back.
Anyone see the same behaviour?
Lee
System Information
App Server IBM WebSphere Application Server 9.0.5.6
Version
Tivoli's process automation engine 7.6.1.0-IFIX20190404-1532 Build 20180718-1141 DB Build V7610-83 HFDB Build HF7610-02
IBM Maximo Asset Management Work Centers 7.6.0.4 Build 20180712-1824 DB Build V7604-119
IBM Maximo Calibration 7.6.0.0 Build 20180718-1141 DB Build V7600-06
IBM Maximo Asset Management Scheduler 7.6.7.1 Build 20180718-1141 DB Build V7671-16 HFDB Build HF7671-05
IBM TPAE Integration Framework 7.6.1.0 Build 20180717-1722 DB Build V7610-02
IBM Maximo Asset Management Scheduler Plus 7.6.7.1 Build 20180718-1141 DB Build V7671-01
IBM TPAE OS/REST Framework 7.6.1.0 Build 20180718-1141 DB Build V7610-38
IBM Maximo Asset Management 7.6.1.0 Build 20180718-1141 DB Build V7604-01
IBM Maximo for Transportation 7.6.2.5-20190415-1043 Build 20180730-2210 DB Build V7625-10 HFDB Build HF7625-07
IBM Maximo for Oil and Gas 7.6.1.0-20190601-1102 Build 20161020-0803 DB Build V7610-139 HFDB Build HF7610-38
IoT Connection Utility 7.6.0.1 Build 20180709-1524 DB Build V7601-02
Server OS Windows Server 2019 10.0
Server DB DB2/LINUXX8664 11.1 (SQL11014)
LEE LE
Agnira Inc
