[Update 1] I was able to achieve this by adding:
My only issue so far is that when adding labor it is off slightly. For example, in MxLoader I told it to add 0:08 minutes to the work order and it added only 0:05. (I think I have found the cause and will update once I test for anyone interested in doing this as well.)
Sent: 06-16-2025 06:48
Subject: Adding Labor and Work Log to Work Orders
Hello all, is it possible to add Labor and Work Log Summary to a Work Order using MXWO object with MxLoader?
Possible use case example, if I wanted to upload a site's historical data (Pre-Maximo) if it was stored in an Excel sheet? I think this could be especially beneficial when trying to use Predict.
- Are there separate objects I would have to use?
- Would I have to create a custom object?
- Can I accomplish this by a relationship?
Thank you in advance,
