Hello All,
I previously submitted a question about this but not in the Discussion format so resubmitting.
When using the Add/Modify Image button in Item Master it states that the only acceptable file type is .jpg or .gif.
When changing the file extensions in the database, this only affects attachments, but not the Add/Modify button.
I was informed that the above file extensions for the Add/Modify button are not editable in Maximo.
Is there a reason it is only open to these 2 image types?
Is there a way to request to IBM that this be something that can be changed?
This affects add images because you either have to take a live picture or convert the saved image to a new file extension to be able to be uploaded.
Thank you
#Administration#Customizations#EndUser#EverythingMaximo------------------------------
