If you have a Dev system that's same as Prod, then just as a starting point, I'd try using Admin Mode in the Dev instance and see if you encounter the same issue. This way, all your Automation Scripts would not run. That would at least quickly point out if a Script is contributing to the problem.
Sent: 07-11-2024 10:11
Subject: BMXAA8229W - Record WORKORDER updated by another user
HI All, I'm having an issue from a user when attempting to complete a task on a work order, we get the BMXAA8229W - Record WORKORDER updated by another user.
I have looked at the logs, but not much there or I haven't found the right place. I have researched on line and some are pointing to a duplicate ID or rowstamp. I was hoping someone would have a script they have used the will at least point me in the right direction. One site said there is an automation script out there. I'm hesitant to upload anything directly from an unknown site as this is a government system. Any thoughts would be appreciated. Thanks..
Brian Swanson
MSTS (Mission Support & Testing Services)
