Assuming the attribute / field was added as persistent, it should work. The object structure would get updated by the database configuration action that added it in the first place. MXLoader however may be out of synch, so you may need to go to the MxLoader tab in Excel and 'Refresh Data Dictionary' or just use the wizard and create a new sheet.
Sent: 10-14-2023 13:00
Subject: Can you add data to a custom field using MX Loader?
| Field: | | Manufacturer Date |
| Table.Column: | | ASSET.TM_MANUFACTUREDATE |
| Manufacturer Date |
Is it possible to load data to a custom field using MX Loader? It hasn't worked for me so far.
