  • 1.  Check access to an object structure
    Posted 05-16-2025 17:11
    Is there a way to check using Rest API if the user has write access to certain object structure?
    Rana Ahmed
    Maximomize
  • 2.  RE: Check access to an object structure
    Posted 05-17-2025 09:57
    Hello
    Create OS to replicate below OS and relationship will be per query-
    MAXUSER
    • GROUPUSER
      • APPLICATIONAUTH
        • SIGOPTION
    SELECT * FROM GROUPUSER WHERE groupname IN (
    SELECT groupname FROM APPLICATIONAUTH WHERE app IN (
    SELECT app FROM SIGOPTION WHERE app IN (
    SELECT intobjectname FROM maxintobject))) AND userid='MAXADMIN'
    IBM Champion 2022|2023|2024|2025
    Lets learn MAS @ https://www.youtube.com/@reliabilityodyssey/
  • 3.  RE: Check access to an object structure
    Posted 05-19-2025 14:23
    Thanks for this.
    Our reuirement is that we are looking for something OOB.
    Rana Ahmed
    Maximomize
  • 4.  RE: Check access to an object structure
    Posted 05-20-2025 15:59
    many thanks
    nasr buzaid
    eni
  • 5.  RE: Check access to an object structure
    Best Answer
    Posted 05-21-2025 08:23
    We have the permission REST API for the logged in user. If you want to get all permissions for a user, you can use this:
    /maximo/oslc/permission/allowedappoptions
    If you want to get for a specific app or object structure, you can use something like this:
    /maximo/oslc/permission/allowedappoptions?app=ASSET
    /maximo/oslc/permission/allowedappoptions?app=MXAPIWODETAIL
  • 6.  RE: Check access to an object structure
    Posted 05-22-2025 11:09
    Hi Steven,
    Thank you for telling us about this API. How do we know or dig further to get all inbuilt APIs?
    Thank you !
    Pavan Uppalanchu
  • 7.  RE: Check access to an object structure
    Posted 05-22-2025 11:36
    Some of the API features are documented in places like: IBM Maximo REST API Guide – IBM Maximo REST API Guide or Maximo - IBM TechXchange Community
    The Maximo REST API also supports the OpenAPI/Swagger documentation. If you access the documentation for Manage (hitting the Manage URL with: /maximo/oas3/api.html ) you can see APIs like this permissions API.
    Enhancements are constantly being made to the product and not all of them are documented unfortunately. A lot of these requirements come from the product team to support requirements they have, especially with the new MAF based applications.
    At the most basic level, if you are in the Object Structures application there is an Add/Modify API Route action. This will show you various handlers available. It won't explain to you how to use them, though, and there are a ton of different options for some like the object structure API. That's why you need to review the other documentation options.
