  • 1.  Conditional default value
    Posted 14 days ago
    Hi to all!
    I want to do something in Maximo that seemed simple and I've gotten stuck, although I admit it's the first time I've tried it.
    In the Preventive Maintenance application, for the worktype field (PM.WORKTYPE) I want to setup a conditional default value.
    If the loggedin user is from the PREV-GS security group, the WORKTYPE value in PM application must be 'GSMAN'. If the user is from another security group, it must be null.
    And I went around and couldn't move forward. I arrived at an automation script, but I don't know how to consult from there the security groups to which the user belongs.
    What I'm looking for is a solution, whatever it may be.
    Has anyone ever analyzed the APPFIELDDEFAULTS table? How can I register data here? I did it from the database, rebooted the system but it didn't do what I need (it didn't do anything).
    I use 7.6.1.2.
  • 2.  RE: Conditional default value
    Posted 14 days ago
    Hello Martin!
    A script like the following could work:
    ## get the username of the logged-on user
    username = mbo.getUserInfo().getUserName().upper();
    ## get a temporary MBO set to see if the user belongs to the group and set a Boolean variable
    prev_GS = False if mbo.getMboSet("$AUTH", "GROUPUSER", "groupname IN ('PREV-GS') AND userid = '" + username + "'").moveFirst() == None else True;
    if (prev_GS):  mbo.setValue("WORKTYPE", "GSMAN");
    else:          mbo.setValueNull("WORKTYPE");
    Jade Warren
    Great River Energy
  • 3.  RE: Conditional default value
    Posted 13 days ago
    Hi Jarred!
    This is my code in python:
    # Obtener la instancia del servidor Maximo
    if prev_GS:
    else:
    It works but always, regardless of whether or not the user belongs to the "PREV-GS" security group
    Regards and thanks for your help!
  • 4.  RE: Conditional default value
    Posted 11 days ago
    Hi @Jade Warren! This script it's working fine so thank you very much for your help in solving it.
    if prev_GS:
    else:
