I'd like to confirm the correct upgrade process when working with an out-of-the-box (OOB) application. Our team has made updates to the RELENGINEER application, and we are currently upgrading to Manage 9.0.14.
Since RELENGINEER is an OOB application, is the proper approach to merge our changes into the OOB version of RELENGINEER delivered in 9.0.14?
After the Manage 9.0.14 upgrade, our plan is as follows:
1. Launch the MAF Configuration Utility: Create a new workspace folder for the 9.0.14 version, open the Configuration Utility, and load the RELENGINEER application (which should now reflect the 9.0.14 version).
2. Retrieve the latest published app.delta.xml file for RELENGINEER from the local development environment.
3. Copy the app.delta.xml into the new 9.0.14 RELENGINEER working directory.
4. Select the Upgrade option in the Configuration Utility.
Can you confirm that this process will apply our custom changes from the app.delta.xml and merge them into the new 9.0.14 app.xml for RELENGINEER?
Mark
#Mobility------------------------------
MARK FRITZ
GM
