Hello everyone,
I'm having an issue with a custom attribute that I added to the ASSET object. I want this attribute to be visible in the Select Value (Lookup) dialog when choosing an asset from the Work Order Tracking application - specifically for a custom field called Asset (Substation).
Here's what I've done so far:
Created a custom attribute in the ASSET object and verified it is persistent, user-defined, and has a value.
Added the field to the Asset application - it shows up correctly there.
Added a crossover domain to copy the value from ASSET to WORKORDER (working fine).
Edited the lookup dialog lookup_wo_asset in Application Designer:
Opened the dialog used when clicking the arrow on Asset (Nenstacion).
THE PROBLEM: Even though the column appears in Application Designer, when I go to Work Order Tracking > click on Select Value (lookup) on Asset (Substation), the column does not appear in the lookup grid.
Any ideas what could be causing the column to not appear at runtime despite showing up in Application Designer?
Could it be a data source issue, or something else I'm missing?
Thank you π
#Administration#Assets#Customizations#MaximoApplicationSuite#WorkManagement------------------------------
Raziela Avdylaj
InfoSoft Business Solutions
