Hello ,
Thanks Mr. Steven and Mr. Sawan for your reply.
Actually i stop JVM and delete record entry from table ServerSession and restarted JVM. Issue Resolved.
syed mehdi
kng
Sent: 07-21-2025 20:14
Subject: Database Configuration Admin mode is not getting off
Assuming the DB config was successful, turning admin mode off and not having the system exit admin mode is almost always related to a service failing to reload. The WebSphere/Maximo logs as Sawan mentioned would be the best indicator of what caused it to fail to exit admin mode.
If the DB config failed, you'll need to do more analysis & figure out how to resolve the issue.
Sent: 07-20-2025 03:12
Database Configuration Admin mode is not getting off when i ran AdminMode OFF from Database Configuration application action.
in the table serversession it shows value 1 for column ADMINCODE
I RUN THE COMMAND TWICE SetAdminMode -mOFF but still Admin Mode is on.
ibm maximo version 7.6.1
syed mehdi
kng
