Hi Gaurav,
First you have to create a non-persistent attribute call "HIGHPRIORITY" in PR Object.
Step 1: Create a Non-Persistent attribute in PR object and name it as "HIGHPRIORITY"
Go to Database Configuration Application --> open PR object --> move to Attribute Tab --> Create a new Attribute (name it as HIGHPRIORITY, provide the title and description) --> Uncheck the "Persistent" checkbox if checked--> Provide the "Default Value" as 1 --> Save the Object --> Turn the Admin Mode On --> Run the DB Configuration
Step 2: Adding and defaulting the Flag in PR application UI
Go to Application Designer --> Open the PR application --> Export the application xml and save it as Backup --> Now add a Checkbox Property in the application xml, name it as "High Priority" and bind it to the PR.HIGHPRIORITY attribute --> Import the application xml.
(Note: You can directly add a checkbox Property from Control Palette option from Application designer UI and name it as "High Priority" and associate it to the PR.HIGHPRIORITY attribute)
Step 3: Verify it in PR application.
Go to the PR application and create a new PR and verify the "High Priority" field is visible in PR application and it has been checked by default.
Subhransu Sekhar Sahoo
Tata Consultancy Services
Sent: 04-20-2023 09:39
Subject: Database configuration Application designer
How to create a non-persistent checkbox high priority on the pr object which is checked by default. Also add that in pr main tab.
I'm new to maximo and requires a deep explanation and demo for the same.
Gaurav Sharma
