Hello all,
I developed a script to either update an existing timesheet or add a new period of timesheet. In the script I convert all dates attributes into a string before to use them in the Set Where statement. BTY, the script is working but at some point generate the following error because of "Adding records" and I don't know why ?
Here is the complete script :
from psdi.mbo import Mbo
from java.util import Date
from psdi.app.common import DateUtility
from java.util.concurrent import TimeUnit
from java.lang import Math
from java.text import SimpleDateFormat
from psdi.security import ConnectionKey
from java.sql import Connection
from java.sql import Statement
from java.time.format import DateTimeFormatter
from java.util import Date, Locale
mAmsActions = MXServer.getMXServer().getMboSet("ZZAMSACTIONS", mbo.getUserInfo())
maximo = MXServer.getMXServer()
mUser = maximo.getUserInfo(user)
mAmsActions.moveFirst()
mGap = mAmsActions.getString("ACTIONS")
mFrom = mAmsActions.getString("PERIOD_FROM")
mFromDate = Date(mFrom)
mTo = mAmsActions.getString("PERIOD_TO")
mToDate = Date(mTo)
mDept = mAmsActions.getString("DEPARTMENT")
mVendor = mAmsActions.getString("COMPANY")
mPunchin = mAmsActions.getString("PUNCH_IN")
mPunchout = mAmsActions.getString("PUNCH_OUT")
mFingerno = mAmsActions.getString("FINGERNO")
mCal = Calendar.getInstance()
mCurrDate = mCal.getTime()
mCreatedate = str(mCurrDate)
mCreateby = "maxadmin"
mTS = MXServer.getMXServer().getMboSet("ZZAMSTIMECARD", mbo.getUserInfo())
mEMPTBL = MXServer.getMXServer().getMboSet("ZZAMSEMP", mbo.getUserInfo())
strt = Calendar.getInstance()
end=Calendar.getInstance()
startdt = mFromDate
strt.setTime(startdt)
enddt = mToDate
end.setTime(enddt)
enddt=end.getTime()
mFingerno='5393'
if mFingerno == '':
errorgroup = "AMSTSCHANGENO"
errorkey = "AMSTSCHANGENO"
# Do it for all employee
mEmptable = mEMPTBL.moveFirst()
while mEmptable:
mFingerno = mEMPTBL.getString("FINGERNO")
mAmsActions.setValue("FINGERNO",mFingerno)
mAct = mAmsActions.save()
#mAmsActions.setValue("DEPARTMENT",str(strt.getTime().date()))
while strt.getTime().before(enddt):
mTsday = str(strt.getTime())
mTS.setWhere("FINGERNO='" + mFingerno + "' and str(TS_DAY)='" + mTsday +"'");
#mTSS = mTS.getMboSet("$NewWO","ZZAMSTIMECARD","FINGERNO='" + mFinger + "' and str(TS_DAY)='" + str(strt.getTime()) +"'");
if mTS:
mTIMESHEET = mTS.add()
mTIMESHEET.setValue("TS_DAY",strt.getTime())
mTIMESHEET.setValue("FINGERNO",mFingerno)
mTIMESHEET.setValue("PUNCH_IN",mPunchin)
mTIMESHEET.setValue("PUNCH_OUT",mPunchout)
mTIMESHEET.setValue("GAP_ACTION",mGap)
mTIMESHEET.setValue("CREATE_DATE",mCreatedate)
mTIMESHEET.setValue("CREATED_BY",mCreateby)
mTIMESHEET.setValue("DESCRIPTION","*****************")
else:
mTS.setValue("PUNCH_IN",mPunchin)
mTS.setValue("PUNCH_OUT",mPunchout)
mTS.setValue("GAP_ACTION",mGap)
mTS.setValue("CHANGE_DATE",mCreatedate)
mTS.setValue("CHANGE_BY",mCreateby)
mTIMESHEET = mTS.save()
strt.add(Calendar.DATE,1)
mEmptable = mEMPTBL.moveNext()
else:
# Do it for one Employee (the one who is entered by the user)
#mTSS = mTS.getMboSet("$NewWO","ZZAMSTIMECARD","FINGERNO='" + mFinger + "' and str(TS_DAY)='" + strt.getTime() +"'");
if mTS:
else:
#Administration#Customizations#EverythingMaximo#MaximoUserGroups------------------------------
Mohammad Moula
eSolution
