Hi John,
The base concept of the SR is that any user (and can be configured for guest access) to raise an SR from the self-service Service Requests app, Maximo Mobile app, via the email listener, etc, without the consumption of a license. This can mean that the issue may get raised multiple times as the user uis not aware that it has already been raised by another user. However, you also have the same user raising another SR as well, either they have forgotten or there is a policy to raise an SR every time you notice the issue.
You'll note that I have avoided the Service Request application as that requires a license, but its design is more from an "I am a service desk/help desk agent logging new SRs". Part of their procedure will be to check if a similar ticket exists, which also includes global tickets. The choice then will be to advise the person that it's already in hand or to log it and include it as part of the global ticket.
There cannot be a duplicate SR number, as the index TICKET_NDX1 stipulates that the combo of the TICKETID and CLASS must be unique.
Back to the underlying issue, that is, people raising another SR for the same issue. This is exactly what the SR has been designed to allow. Why? When you have lots of people raising the same issue on the same asset/location it means that the system is working. It very valuable information and means that a global ticket should be raised and that there should be procedures to have that info front and center.
How does that fit?
- Same SR number. Nope each will be different
- Same asset/location = yes
- Same classification = yes
- Status (other than CLOSED, REJECTED, CANCELLED, RESOLVED) = not important as the issue is not fixed
What does that mean? You can build an index that ensures the combo of the asset/location + classification is unique, but I'd counsel that you examine if that is enough of a true statement as the issue could possibly be different.
I would be interested about if any one finds that
Principal Consultant
COSOL
email:
craig.kokay@cosol.global#IBMChampion
Sent: 10-02-2025 12:51
Subject: Duplicate SR tickets in MAS 9.1
Looking for solution on how to configure Service Requests (MXSR) object to not allow duplicate SR tickets, I believe this was done in MAS 8.x and prior in SR Config Work Centers properties, unable to locate similar functionality in MAS 9.1.
John Zupet
IBM Corporation
