You can check the container logs on your Docker Desktop. If you see a similar message below, it means your container tried to use more memory than you have available. Try restarting your PC and stopping other apps.
INFO: server/29 on 5cd454d91e2d: received a get request to get application TECHMOBILE status (req_id=2b680fef-8457-46bf-a068-a4e17ecd7454)
The build failed because the process exited too early. This probably means the system ran out of memory or someone called `kill -9` on the process.
[2024-01-21T23:29:59.381Z] ERROR: server/29 on 5cd454d91e2d: 1
[2024-01-21T23:29:59.387Z] ERROR: server/29 on 5cd454d91e2d: 1 (req_id=2b680fef-8457-46bf-a068-a4e17ecd7454)
Maycon Belfort
BPD Zenith
Sent: 01-17-2024 15:12
Subject: Error For Publishing TECHMOBILE
Hi Souvik,
Have you been able to find a solution to this?
Nathan Tabenkin
Starboard Consulting
Sent: 11-22-2023 10:22
Receiving below error at the time of publishing TECHMOBILE xml
Anyone can suggest where I can check the logs
Souvik Dutta
TCS
