We are on maximo 7.6.1
I have a requirement where the E-Signature dialog has to be presented to the user, as soon as they hit on route worlflow in the invoices application.
Here is how i have configured it, but this does not seem to work.
In the
Database configuration application:
Manage eSig Actions dialog: Filtered for
Invoices application and under the Options for Invoices application at the bottom filtered for
Route Workflow option and
checked the
E-Signature Enabled? check box.
In the
Application Designer:
Add/Modify Signature Options dialog: Filtered for
ROUTEWF option and
checked the
After the above settings, i went to Invocies applications and picked a record and started worklfow on it. I have not received the e-signature dialog but the workflow is started on that record.
Is there something that i have missed in the configuration or is it just the restrictions in maximo where e-signature does not work with workflows.
Thank You.
#Customizations------------------------------
vikky k
Idyllic Solutions
