Thank you @Prashant Sharma.
I seem to be having trouble now when trying to add assets to a Job Plan that has no ORG or SITEID.
I receive this message: Internal Server Error
Error 500: BMXAA2147E - Work asset must have an organization.
I added the columns below and it did not resolve the error so I am assuming it has to do with the Job Plan not having an ORG?
| JPASSETSPLINK.ORGID |
JPASSETSPLINK.SITEID |
I was curious if there is a way still to add the assets to a Job Plan without an ORG.
Thank you for any advice :)
Sent: 10-03-2023 11:16
Subject: How to add Multiple Assets to Single Job Plan?
Go to Object Structure > Search MXL_JOBPLAN. In that add object JPASSETSPLINK and include all required fields. Now you can query 1 Job Plan with Asset and then load all others after removing unwanted fields.
Sedin Technologies
#IBM Champion 2022
#IBM Champion 2023
Sent: 10-03-2023 10:00
Hello all, right now MXLoader tries to create a new Job Plan for each row when trying to add Assets. So how can I add multiple assets under the Work Assets tab using MXLoader? Is this possible?
Thank you
