We are in the process of doing this on all our servers. We were unable to do an OS update and instead had to create new 2019 servers and install Maximo on those servers and then migrate and update the database in SQL Server (we are using MS SQL server and it has an update procedure inherent in it) and then updatedb in Maximo. If you don't use an image to do this and you choose to install Maximo from scratch you will need to bypass the Prereq check on the installation file because the older installation files don't like 2019.
1) Click the Start menu.
2) Right-click Command Prompt and select Run as administrator. The Administrator: Command Prompt dialog box is displayed.
3) Enter the following command :
set BYPASS_PRS=True
set CTG_BYPASS_PREREQ_CHECK=true
4) Run the following command in the same window:
IBMIM.exe
Megan Matthews
NAES
Sent: 05-16-2023 00:55
Subject: Impact of Windows OS Upgrade in Maximo
Hello all,
We are planning upgrade of windows server from 2012 to windows 2019.
The current maximo version is 7.6.1.3 and Websphere version is 9.0.5.13
Will there be any impact to the Maximo or Websphere?
How will the "System information" in maximo is refreshed? Will it be updated automatically otr any stpes required.
Kindly clarify.
Thanks!
Sankar
Sankar Ganesh V S
DXC Technology
