Thank Prashant Sharma for your suggestion.
I missed a key point, my expectation is setting a value for the memo field in the complete workflow assignment dialog when a specific user clicks route workflow.
[Acey] [Nguyen]
[NGS]
Sent: 04-01-2023 11:19
Subject: Is there any way to set a default value for the memo field in the Complete Workflow Assignment dialog?
Hello - Go to Database Configuration and Open COMPLETEWF. Go to Attribute > Memo and set the default value as Approved. Perform ConfigDB and then test the WF.
One done, Approved will set in Memo
Sedin Technologies
#IBM Champion 2022
#IBM Champion 2023
Sent: 03-31-2023 00:36
Each time user clicks the route workflow button in the application, Maximo will automatically set a value for the memo field like "Approved".
Any help would be appreciated, thank you.
[Acey] [Nguyen]
[NGS]
