  • 1.  MAS 9 the missing Pick list
    Posted 02-11-2025 09:34
    I have some question over the picking and staging option not in MAS9. Previously there was a Work Center for this now deprecated.
    There is now a Pick List? toggle in the Inventory Usage app but this is Read Only.
    Does anyone have any clue of how this now works in MAS9? i cannot find any information at the moment...
    Lee Daley
    BPD Zenith
  • 2.  RE: MAS 9 the missing Pick list
    Posted 02-12-2025 13:04
    Hi Lee,
    I posted a similar answer to the TechXchange, but in case you didn't see that, I am posting it here as well.
    The Pick and Stage functionality uses Inventory Usage under the covers and as such, some of pick and stage is available in MAS 9 (kind of).  If you go to the Inventory Module, Role Based Applications and then select Issues and Transfers and finally select Inventory usage records.  From there you can stage inventory usage lines, kind of like you used to be able to, but the functionality clearly has been curtailed.  I have heard on roadmap calls that there is the intent to build this back in, but it is unclear when that will happen.
    I generally do not use this as a platform to promote our commercial products, but in this case it is hopefully relevant to you.  We have been working with a partner client and have fully developed Pick and Stage support in our Opqo mobile product (https://opqo.io). It fully implements all the pick and stage functions and is compatible with MAS 9. It will be generally available the first week of March, but if you would like to try it out sooner feel free to reach out and I can provide you with the configuration script to enable it, my email is jason@sharptere.io
    Hope that is helpful.
    Jason
    Jason VenHuizen
    Sharptree
