MAS SNO installation on AWS
  • 1.  MAS SNO installation on AWS
    Posted 06-12-2025 20:34
    Hi All, I am using below tech note to install MAS using AWS single node approach.
    Save Costs with Single Node OpenShift Deployments of IBM Maximo on AWS | Amazon Web Services
    I followed all the prerequisites per this note. However, I am encountering the following errors when creating the OpenShift cluster on using mas provision-aws command.
    FAILED - RETRYING: [localhost]: ipi : Create cluster (4 retries left).
    FAILED - RETRYING: [localhost]: ipi : Create cluster (3 retries left).
    Upon checking my AWS console, it is creating multiple VPCs may be due to retrying.
    Here is my AWS Cluster Configuration
    Cluster Name - maximodemo
    AWS Region - XXXX
    AWS Base Domain - dummydomain.com
    This dummydomain.com is already existing in AWS which is used for other resources. Once mas provision command fails it creates another DNS by combining cluster name and AWS Base domain ie maximodemo.dummydomain.com.
    Any thoughts on what should I be checking? Thanks
    Amazon Web Services remove preview
    IBM Maximo Application Suite (MAS), when paired with Red Hat Single Node OpenShift (SNO) on AWS offers an agile, cost-effective solution for asset management within SME (Small and Medium scale) settings. This simplified OpenShift configuration converges control and worker functionalities into a single Amazon Elastic Compute Cloud (Amazon EC2) node, fostering a lightweight, streamlined Kubernetes [...]
    View this on Amazon Web Services >
    SA
    Accenture
