Thank you Every one for the replies. This was a bug in Mobile IFIX 02 which is addresssed by IBM in IFIX 06.
Thank you again.
vineet joshi
Sent: 03-18-2024 19:34
Subject: Maximo Mobile
I saw this error when my application server and my DB server were not in the same timezone.
When you create a work order in Maximo desktop, do you see the correct time in the WO Reported Date? If it's not correct (even when you are in the right timezone set in your Default Person profile), there then there is timezone mismatch issue.
In my case, it was one hour behind due to different timezone. I got my application server timezone updated and issue got fixed.
Sent: 03-12-2024 16:51
Hello All
I am getting this error in Maximo Mobile 8.11 (Maximo mobile out of the box).
Steps to reproduce:
- Login to Maximo mobile and let the data sync be complete.
- Go offline
- Create New Workorder
- Approve the workorder
- Go to add Labor. Update the Start date and Start Time (Start and End timer not used)
- Complete the workorder( Used blue Check box)
- Go online and wait. Out of 4 transactions 3 went through
- Below error shows up.
Vineet
vineet joshi
