Were upgrading our application and integration servers from 2012 R2 to either 2016 or 2019
Currently our database server is on SQL 2016.
Is WebSphere version 8.5.5.X compatible with 2016 or 2019 servers?
According to the version matrix from IBM it looks like it is can someone confirm.
Current - System Information
App Server IBM WebSphere Application Server 8.5.5.14
Version
Tivoli's process automation engine 7.6.1.3-IFIX20230324-1804 Build 20220823-0909 DB Build V7613-344 HFDB Build HF7613-67
IBM Maximo Application Framework 8.8.0 Build 20220823-1257 DB Build V7600-23
IBM Maximo Asset Management Scheduler 7.6.8.2 Build 20220823-0909 DB Build V7682-23 HFDB Build HF7682-08
IBM Tpae Integration Framework 7.6.1.3 Build 20220823-0909 DB Build V7613-61
IBM Maximo Spatial Asset Management 7.6.1.1 Build 20230406-1733 DB Build V7611-24 HFDB Build HF7611-07
IBM Maximo Asset Management 7.6.1.3 Build 20220823-0909 DB Build V7611-01
IoT Connection Utility 7.6.0.4 Build 20220303-1642 DB Build V7604-01
Server OS Windows Server 2012 R2 6.3
Server DB Microsoft SQL Server 13.0 (13.00.7024)
(c) Copyright IBM Corp. 2021
#Administration------------------------------
Diane Nohner
City of Minneapolis
